1 - 9 of 9 Posts
I have a floor joist I want to drill through for some electrical wire. There is already an existing hole drilled for some current wiring that came with the house. The floor joist is a particle board type nailed together. I attached a photo of the joist.
marly
Registered User
Discussion Starter · #6 ·
Measure the two LVL's, if 1-32/4" each, that is what they are, pp. 23: http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=32941&Variant=Original
If they measure 1-1/8" or 1-1/4", they may just be rim boards; http://www.ilevel.com/literature/TJ-4000.pdf (I hope not....)
Gary
They measure 1-3/4" (assume you meant 1-3/4 instead of 1-32/4"). They'are also used exactly how they're used in the picture on pp. 23 in the link you gave. They're buit around the stairs going into the basement.
I also have another joist similar that measure 3-1/2" that's labeled iLevel Truss Joist.
marly
Registered User
Correct, I usually spell check myself, but have been sick at home today. That is my excuse and I'm sticking by it.... LOL.
Follow the guide or find the U.S. version on-line.....
Gary
Discussion Starter · #8 ·
Gary
I attached another picture. I found on the back side it says, "Trus Joist" and it also says "hole zone". I assume that's where it's ok to drill.
Registered User
1 - 9 of 9 Posts
