What bolts or other parts do I need to drill the plaque in the photo below into a hollow stucco wall? Will the anchor kit in the photo below work? Thank you for your advice.
Drywall/hollow wall anchors suck, they rarely work well. Can you find the studs? If you can put a single screw into a stud, you could then hang it from a wire via the plaque's 2 holes. And the hanger will be much stronger, self leveling and you won't make a mess of the wall. But you will see a bit of wire on the plaque.. unless you use fishing wire.
