1 - 18 of 18 Posts
Im adding a sub panel and need to run a 1 1/4" conduit. I would like to put the conduit in the wall but wondering what is the maximum size hole that I can drill through the studs. It would probably need to be drilled 1 1/2" size and have to drill about 6 studs. I can run it surface if needed but would like to put it inside the wall.
Whats the max size I can drill through the studs?
If it's not a bearing wall, I wouldn't be concerned. You still have an inch on each side left.
Think about steel studs. They have 1bout 1 1/2 inch holes punched in them every couple feet.
Technically, I don't know the answer. :jester:
Thats exactly what I was thinking also, "technically" I dont know the answer either:huh:
· Licensed Electrical Cont.
40% allowed in bearing walls and 60% allowed in non-bearing walls.
For a 2x4 this is 1-7/16" or 2-1/8"
Either way you will need nail plates on BOTH sides of every stud.
I believe you, so don't take this question the wrong way. Could you provide a code citation? This is really good information, and I would like to be able to tell people this and back it up. Thanks, sincerely.
· Registered User
I have this Wood Boring Guide .pdf file. It is from:
Western Wood Products Association
522 SW Fifth Avenue Suite 400
Portland, OR 97204-2122
503/224-3930 Fax: 503/224-3934
e-mail: [email protected]
web site: http://www.wwpa.org
I don't remember where I got it but you can try it here: http://www2.wwpa.org/Portals/9/docs/PDF/A11.pdf
I had to join their site to see if it was still available. It is but you may have to join (for free).
· Chicago, IL
- http://www.canyonco.org/dsd.aspx?id=8823
____________
Home Inspection: "A business with illogically high liability, slim profit margins and limited economies of scale. An incredibly diverse, multi-disciplined consulting service, delivered under difficult in-field circumstances, before a hostile audience in an impossibly short time frame, requiring the production of an extraordinarily detailed technical report, almost instantly, without benefit of research facilities or resources." - Alan Carson
· Chicago, IL
- http://www.canyonco.org/dsd.aspx?id=8822
· Electrical Contractor
Im adding a sub panel and need to run a 1 1/4" conduit.....It would probably need to be drilled 1 1/2" size....
You will need a minimum 1-3/4" hole size to accommodate a 1¼" trade size conduit.
If you are installing PVC conduit, then a 2" hole is required for any couplings to pass through.
1 - 18 of 18 Posts
