I have this old school rockwell drill press that works pretty well other than having a steel plate for the table. I decided to make one that would be pretty functional for using hold downs etc, but for spending under 30$ & using left over stuff I'm pretty stoked.
First drawing/layout
Center will have a replaceable plug, I'm masking it off so I can bondo it to make an exact replica which I can then use to make the jig that will sit on the wall for whenever I need replacements.
Piece for jig
Final jig
Added some laminate from leftover deathstar project, a little too dark and already has built in scratches, but it's better than nothing
In place
Additional screw on leafs for bigger parts. I didn't want to always be reaching over some huge table but also didn't want to flail when drilling a cabinet door or something so I used some machine screws and t-nuts to add on extension pieces
Sacrificial plug in place
Got the fence done, I used some extruded aluminum t track and built some stop blocks too
Piece for jig
Final jig
In place
