1 - 11 of 11 Posts
What’s better or more popular? We’re replacing our bathroom cabinet doors and drawer fronts. For the doors we’re going with soft close hinges. Just have to decide what to do for the drawer fronts.
· Remodel and New Build GC
I'm not sure I'm familiar with all updates.....but I just use side mounts as I think they provide a much better feel for the price. Yoy can get them self close etc....I like the ball bearing style...I think its worthwhile.
· A "Handy Husband"
Unless you are replacing the drawer boxes you need to use the same style you have. The drawer boxes would have to be modified to change from side to bottom or the reverse. Use quality ball bearing, soft close slides.
Sent from my RCT6A03W13E using Tapatalk
I may be wrong but I think the drawers are built to use one or the other, side mounts cause the drawer to be bit a little smaller. Side mounts make be at the middle or bottom of the side.
The bottom mounts I am referring to the track are the true bottom mounts not the side mount track that mounts at the bottom side of the drawer.
If you have face frames....the side mounts do not attach to the sides of your cabinets....they attach to the front frame and then to the cabinet back.
It is essential that you have those slides dead parellel and in the same plane.
It is phsically difficult for me to do that in locating the cabinet back slide holders in allready installed cabinets.
So I measure carefully, and make a back plate "jig" (normally a piece of 3/4 pine as there usually enough room between the drawer and back) that I can very carefully precisely mount those back slide holders while up on top of a workbench.
Then just attach that backplate "jig" to the cabinet.
Just an idea....
1 - 11 of 11 Posts
