So I spent some time learning about how the furnace system works in my house and then i went and traced the whole system so I understand what does what. My plan is to drain the second zone so I can remove the pipes to remodel the wall so I want to make sure I'm doing this right before I proceed.
My understanding is I need to do these steps.
1.) Shut the return valve off for the zone I want to bleed.(#1 in photo)
2.) Attached hose to spigot and open that to drain the water out the hose(#2 in photo)
So, here is where I have a question.
- Will the pipe empty or will the water just be replaced to keep the pressure the same? I know I have that "thing"(number 4 in photo) that will add water to keep the pressure the same.
- If the heat is off for that zone will water still flow from the zone control(#3 in picture)?
- Should I shut the water completely off to the system(blue knob below the number 4).
If I don't need to shut the water off because it wont flow through the zone valve when it's off how do I force it open when it's time to refill it?
