Hello,
I'm currently in the process of digging out an area for a retaining wall. My backyard is such that the water from the home behind me runs down towards my home and then passes between our home.
Since my retaining wall that I'm building is over top of the area that most of the drainage occurs, I've cut out the trench for the retaining wall and in the middle of (underneath where all the soil will go) I'm going to add a drainage tile. The wall itself will probably be somewhere like 2 to 3 feet high -- stepping up every few feet towards the fence at the back of my home -- since the slope is downwards towards my home.
In order to resolve the drainage issue and keep my retaining wall from separating/falling, I'm building in a trench for a drainage tile. I'm unsure of the size I will need (diameter of the drainage pipe) and whether or not I will need landscaping fabric.
I know I can get the drainage pipe witha sleeve on it, put it in the trench and bury 5-6 inches of drainage rocks/stones over top of it, but will I still need the landscaping fabric over top of the rocks to keep the soil from getting into the rocks. OR is that just overkill and does the sleeve on the drainage tile do the same job as the landscaping fabric. If I do need landscaping fabric any ideas on the width I'll need?
The length of the pipe that I will need to run will need to be about 18feet or so...
i apologize if this is a lengthy question but any ideas would be greatly appreciated. I don't often do these kind of jobs so am kind of clueless (but learning).
Thanks in advance!
Thanks in advance!
