I'm installing a double sink vanity in our bathroom remodeling project. The vent is to the right of both sinks so I need to run the waste drain from from the first sink past the second sink to get to the main line. I'm using a 90 at the first sink, a sanitary tee at the second sink and a long sanitary tee where the drain meets the vent.
Any concerns with this layout?
When you install the P-Trap there is a pipe that goes from the trap into the wall. The wall has a threaded fitting that allows a ring to seal the pipe. What is the threaded fitting called----P-Trap Adapter?????
