C on top B center A at the bottom as per your drawing.
This is what the code wants a mechanical discharge at the bottom of a gravity drain. and then it would be lavatory sink above a line discharging solids which would be your disposal. plumbing systems are designed to self cleaning, you always want clean water up stream of a solids discharge. also like others have mentioned length of those waste arms are important. if your in the south east your probably under the IPC thats the one we are under but we also have the south Florida plumbing code which covers areas not addressed under the IPC. should check with your local building official. hope this helps.
Thank you, everyone that have taken time to respond to my post since the start.
I have revalidated and reviewed the 3-pipe stack configuration approach and have decided to go with a 2-pipe stack configuration. It only appears to be more feasible from the stand-point of how the pipe would fit both through the studs and at the drain stub-out - two 2" pipes would be best while staying in the proper drain heights (i.e. 14" for kitchen sink with disposal, Lav/Vanity at 18", etc.). These three fixtures will be on the same wall from left to right toward the 3" drain pipe with an air vent as drawn in the sketch.
Please take a look at the drawing that I have put together, and check my knowledge. I am open for constructive criticisms and suggestions, as some of you truly have been great and thorough in helping me.
Thank you again in advance.
