1 - 20 of 38 Posts
Hi all!
I have an ejector pit in my basement, which receives a floor drain and rough-ins for a bathroom (not finished, plan to in future). Currently the ejector pit contains a sump pump, not ejector pump.
I would like to add a utility sink to the area, and drain into this pit. I wanted to see if a wet vent would be the best approach, and if this is the correct application.
Thanks all!
· Premium Member
Thanks for the feedback. Is there a better way to plumb this?
The only other way is to bust up the floor or find a waste line for the current rough in and tie into it.
If it was me- I'd use your plan and consider a pump that would handle any solids that would get by the sink
Thanks for the reminder on waste. I do have to be careful to put liquids only. The sink has a pretty specific use, so there should be no problem with that.
If draining into a new hole in the lid will the sink be vented via the vent in the pit, or does something else need to be added to make it vented?
that is the drain side, and the fitting you use to tie into the 2 inch is called a ty, you see how the side that goes to the trap, that is called the bull of a T, and how it angles down, well on the vent side you turn it the other way so the bull angles upward..depending on how far away the sink is from the 2 inch vent, you may have to run an additional vent back to the trap..
· Premium Member
Garrett, cut in a 2x1.5" sanitary tee at the sump vent.
Then run an 1.5" trap arm as your picture shows. Support the trap arm from sagging and your done.
My UPC code allows a 1.5" trap arm length of 42" before preventing it. I believe IPC is a bit further in length.
Discussion Starter · #16 ·
I certainly do have a lot of opinions. If my count is correct, between here and others I have talked to I now have five different suggestions. Including two which are the same but change the direction of the ty fitting. Very confusing. The sink isn't worth concrete work to me; I am only going to add it if its simple, otherwise I can do without.
I guess I will see which looks easiest to undo, in case it doesnt work, and go that route!
1 - 20 of 38 Posts
