I think I might have spent a while under the house for nothing. I thought the new elbow I was putting on hit the hole perfectly. After further inspect its not perfect. The flange that I have the front mounting holes barely if at all hit the floor I'm drilling into. Should I go get another elbow and couple to fit it again or is there a flange with a larger mounting ring that will work? Thanks for your suggestions.
Additional information the floor to the drain is about 1 inch so I need to get a new flange that has a 2 inch neck.
