Currently trying to plumb a drain from a freestanding (with legs) bath vanity down into the crawlspace and onward to the waste/vent, 5' away. Problem is that the vanity will be located on an 2x4 exterior wall. The wall/floor plate is also on the concrete foundation with the rim joist still a few inches inside the envelope. So, I won't be able to drill down through the plate for the 2" drain, and any void under the floor starts at about 2" inside the room.
Apparently, I cannot use an s-trap to go straight down through the floor, but instead have to use a p-trap into the wall!
What's the best way to plumb this vanity if it cannot go hidden into the wall then downstairs via through the plate?
This is a corner room with 2 exterior walls at right angles to one another.
