Daughter bought new house (for them) build in 2005.
From the panel, a 20A 2-pole CB feeds into 2 separate single pole switches in a 2-gang box, from there feeding a split receptacle under the island sink base cabinet. One switch for DW and the other for GD.
I want to use the right-side switch for the light over the breakfast nook because I am removing the partition wall that the only switch for that light is on (strange that the light is not on a 3-way switch setup).
The dishwasher has a cord and I don't think it was ever hard-wired given it's the original DW - perhaps just the old kid-proof approach.
So I will remove the red and black from that switch and tie them together so that half of split receptacle is always hot and that will be for the DW. The GD wiring stays as is (switched).
Then I can use the now free switch for breakfast light which is on a separate 15A circuit. I'm not a big fan of having 15A and 20A circuits in same box but in this case no easy way around it. I will tie all grounds together but keep the neutrals separate.
Good to go as described ?
Thanks very much.
Thanks very much.
