1 - 11 of 11 Posts
Hi fellow DYIer,
I just bought a home last year and is slowly trying to address some issues around the house. Here is my current project:
Sink A: Sink with no garbage disposal.
Sink B: Sink with garbage disposal.
When using the garbage disposal, there will be food particles that is shot up from the sink A. Attached is the plumbing for the sinks.
From what I understand, I need a baffle T for the sink A. While changing the pipes, I am also looking to replace my garbage disposal as it gets jammed pretty frequently.
trying to achieve:
1. Stop food particles from shooting up sink A when using garbage disposal
2. Change garbage disposal to a new model
3. Put a high loop for the dishwasher outlet
Any help is greatly appreciated.
Thanks
Hi Ghostmaker, I'm sorry but I am having a hard time visualizing what you are trying to point out to me. I edited the main picture to include an alphabet for each part of the pipes.
If I install an end outlet waste kit, the pipe down Sink A will be straight down, and this will no longer align with the P trap at the bottom to connect to pipe F.
Thanks
· Premium Member
Pipe it as the third image shows- end outlet disposal kit.
Also, you tee may not have the correct baffle orientation.
Does your sink drain OK?
Discussion Starter · #6 ·
I notice that Sink A drains a little slower than Sink B. What does this indicate?
I am also guessing that the center T baffle orientation is not correct or the inner baffle might be broken. I will remove the center T this long weekend and inspect it.
Thanks
· Premium Member
To remove the tee- loosen nut B, E and D
I assume this is to inspect the Tee?
Unscrew the nuts and gently pull and wiggle the pieces apart
Discussion Starter · #9 ·
I have managed to change the old T with a baffled T. THe old T has no divider inside to block the flow path from B to A.
With the newly installed T, using the garbage disposal, food particles are no longer shooting up sink A.
Thanks all who helped. :)
Another question:-
1. I see some rust on the garbage disposal. Is that something to worry about? Why is the garbage disposal rusing on the top where it is mounted?
Fill up the bowel of your sink on one side and let it drain. If you get anything up the other side you need to snake the drain from the trap downstream. A high loop on your dishwasher hose is also a good idea unless you have a newer dishwasher with the loop built on it.
1 - 11 of 11 Posts
