I am finishing carpet grade stairs in my basement. Going with a stair re-tread product, although I haven't selected one yet. Doing the treads and risers looks fairly straightforward. My problem is with the landing. All the instructions and videos I've seen show a landing that makes a 90 degree turn so that there is only one edge that requires a landing tread, the other three sides are walls and a riser. So the installer butts the landing floorboards up to the landing tread and works back to the wall, where a gap is left and covered with trim. My landing platform has a two landing treads, so when you come down the stairs you can either turn right or left and step down. There is a wall opposite the last riser. How do I install the landing floorboards so that they butt tight against both landing treads? I think I need to rip the floorboards (they will run parallel to the treads) to fit on either side, cut a groove and spline them to the treads. Does that sound right? Are the boards nailed or glued to the plywood landing platform?
Thanks.
Whole thing made no since to me.
Why not get rid of the old covering on the stringers and install real treads?
Only place I've used a landing tread is at the top of the stairs.
· JUSTA MEMBER
Figure out how many full width boards it takes to cover this, with a remainder.
Divide that remainder in half. That is what you rip a board to, to have a symmetrical pattern on each side.
Start in the center of the landing, and work both ways out, using a spline on the side without a tongue to be able to turn the second board around.
otherwise it will look OFF and your happiness will be less.
As for attachment, I would toe-screw this together. To hide any sign of attachment.
ED
