1 - 17 of 17 Posts
Hi there, I have wired some lights, they are working but not how they should and I was hoping someone could look over my design. Below is a picture I drew of the set up, I'll explain more and discuss the problem below.
Now the switch I am using is exactly like the one above.
Each light (2) have a dedicated switch. The problem is that yes the lights work but the switches work opposite, as in one switch turns the light on in the off position and the other does the opposite if you catch my drift.
There is no loop on the diagram because there is no ground wires.
Any help would be much appreciated.
A "Handy Husband"
What country are you in?
A "Handy Husband"
If the switches are single pole, double throw, if switch A is closed to terminal 1 it blows the breaker. If switch B is closed to terminal 2, left lamp will light. Right lamp is lit all the time.
Better review your homework more carefully.
Discussion Starter #6
Thanks for the reply, however, I'm not entirely sure what any of that really means, I have a general grasp on wiring but this one has me stumped. Both lights switch on individually, like they should but they don't both "flick down" one flicks down the other flicks up to light up.
The back of the switches have one of these above behind both.
Regardless of whether you are using 12 volts or 120 volts or 240 volts and regardless of whether you are using alternating current or direct current, the wiring as you described does not work as you described.
At least according to USA descriptions of switch terminal labeling.
Discussion Starter #8 (Edited)
@AllanJ Strangely enough there is no blow outs nor lights remaining on, only the weird switch issue, below is an idea of what the switches would look like with both lights on. Not uniform if you know what I mean.
If someone could correct my diagram or provide an idea of how it should be wired I would be gratefully appreciative.
Super Moderator
You going to have wait fro someone with knowledge of NZ switching. Most of the people here are from North America. WE don't have any switches like the one you show.
I don't see how the right would not be on all the time. Please review you wiring and make sure the diagram is how you actually wired the system.
The wiring is wrong !
1 - turn power off.
2 - move the black wires to the loop terminals.
3 - join the two loop terminals in both switchs,
with a short length of black wire.
4 - move the red wire in switch B to terminal C.
5 - move red wire of switch B to terminal 1.
6 - The red wire of light A should go to terminal 1
on switch A.
Your picture shows this wire going to the main supply
Which is not correct, it needs to go to switch A terminal 1.
And no where else !
If your supplied drawing is truelly representitive of what
You have done ? Then it would not work
So I am assuming it is wrong !
Be safe be careful
Let us know how you go ?
Just so our american friends know what is going on !
This O/P is in New Zealand which is near Australia.
So the color scheme is the old Australian scheme
So Red is hot or active.
And Black is neutral.
Which is different to USA where black is hot.
A "Handy Husband"
How does the switch work, what is the loop terminal used for?
Why is the right side light not lit all the time? It seems to be connected to a hot and neutral with out a switch.
Reactions: ritelec
Looks like one is switched and one stays on.
What is loop????
Heard NZ is a nice place. Expensive but nice.
What is loop????
Change that. Looks like one stays on and one switches on/on.
Loop terminal is not connected to the switch at all.
It is just for terminating wires
Or joining wires such as the neutral.
And yes the light on the right can not work
If it is wired as shownon the diagram.
I suspect the drawing is wrong
Hense my comment in reply.
Cause the op said they are working
Sort of !
1 - 17 of 17 Posts
