Hi! I am asking if anyone can tell me if this framing can be removed completely. It was a linen closet in upstairs bathroom, and it did have (2) 2 X 10's over the opening along with 2 cripple studs above it, but there was no plywood layer glued between the 2 by 10's.
I don't think these walls are load-bearing; one is a wet wall for the tub supply piping. What I want to do is remove only the 2 x 4" wet wall to right and remainder of door opening framing, and install new tub here. There is access to install tub plumbing from a closet behind wall to left in photos.
I will sister joists underneath (has 2 x 10" joists) and install new 3/4" plywood subfloor here. Two of joists were sistered (Had scratched-up Kohler cast iron tub. I'm replacing with Kohler Bellwether K8370 cast iron tub) but one of them had a section removed to accomodate bathtub drain.
Which means I may have to sister this joist on the other side to avoid the same drain problem.
Thanks for any replies!
