1 - 14 of 14 Posts
My house was built in the mid 60s and has popcorn ceilings. I hate the way it looks and Ilit's possible that it can contain asbestos. I've seen suggestions of covering it up with another sheet of drywall. I was wondering if I do go the route of encapsulating the popcorn ceiling (if it contains asbestos), will the extra sheets of 1/2 drywall be a weight issue? The manufacturer specs say it's around 39 pounds a sheet.
Edit: Not sure if this is useful but I forgot to mention the joists are 24 inches apart
· retired framer
Have you ever got up and walked on the 2x4s in the attic. If you did you likely loaded them more than the drywall would. I think they are closer to 60 pounds each.
How many sheet to do the room times ? the wait divided by the number of 2x4s and you will have the extra loading for each.
· retired framer
I have and it seemed fine although I did calculate I would need about 12 sheets of 4x8. That's a lot more than I weigh :biggrin2:
So something like 1200 pounds less some as the are supported to a near by wall so maybe 1000 pounds divided by the 2x4 not near a wall.
I suppose you could put struts from the 2x4s up to the rafters in the middle.
· Red Seal Electrician
Giving this a try,take a pump up sprayer with water in it and spray the popcorn getting it wet.Let it set awhile then take a wide drywall blade and scrap off the popcorn.
If its been painted over, it doesn't come off easy.
I had an older/smaller dining and living room to do. I gave up after the dining room. Won't tackle one again. Life's too short to spend time on drywall. Change the colour with paint, or move. :biggrin2:
Like what you side,scrap off what will come off then paint over it.Just won't look like popcorn anymore.Fingers cross
Different opinion, just install the sheetrock. Use lightweight if you want. But if you use the regular, No worries. You don’t need extra support. YOUR weight is a point load. The SHEETROCK Weight is spread across the whole ceiling. Looking another way, I weigh 170, my deck is built to 40 psi, so I put 170 on like 2 ft of deck, I should be on the ground. But of course the structure spreads the weight around.
I would remove the popcorn. What do I need extra weight on so few joists for?
When you remove popcorn by wetting it, plus wear protection, it's not difficult and you can do one room at a time. A good idea would be to empty the room and tarp the floor wall to wall.
1 - 14 of 14 Posts
