I am trying to replace a doorbell chime box in an existing home with a front and back door bell switch. someone removed the old one without labeling the wires.
There are 2 whites and 2 reds at the chime box. It it touch the two whites together i get a little spark. If I touch any other combination of wires I see nothing. if i touch one white wire to the transforer connection point on chime and the other to front it will chime. Of course the doorbell switch is not pressed in so this is not the correct connection. I would greatly appreciate advice on which wire to hook where.
PS: I checked both doorbell switches and each has a red and white wire attached.
Thanks
Dan
Thanks
Dan
