Hello,
I'd like to replace a door in my basement.
I think I'll will have to rip out all the current framing, and end up with simply the cement “hole”. This cement hole measures about 33.5” by 72”. I figure its best to rip out the current framing, as its old, and if I were to keep it, the new door I’d install would end up being smaller, as the old frame is about 1” thick on each side. I need a wide door, as sometimes I’ll use this door to move stuff in and out of the basement. My new door will be about 32” wide, and including the frame should be about 33.5”.
Now here’s my question. Assuming I rip out all of the old framing, can I simply install my new pre-hung door, level it, shim it, and then secure it with cement screws aka Tapcons (blue screws)(2 or 3 on each side for a total of 4-6 screws)? I’d then fill in any gaps (i.e. spaces between the concrete door frame, and the pre-hung door I’ve installed) with spray foam (low expansion as not to buckle the door frame), or the pink wool type insulation. If needed, a bead of silicone around it all.
Do you guys see anything wrong with this approach?
I'd like to apply the same thing to a window, again in the basement, and it would be approached the same way as well. Any concerns here?
Thanks guys & gals, Have a nice day!!
