1 - 8 of 8 Posts
· DIY Expert in Training!
I am finishing a remodeling project. The one door has vent soffits above both sides and is tight to one wall. Therefore, on one side I can fit traditional trim on both sides but not the top. On the other I only have about 1 1/2 on the right, 3-4" on the left and 1 1/2 on top.
How do you suggest trimming this out?
Thanks!
Kevin
· Registered User
Center so one side casings are same width. If door is not near another, cut jambs and door down to get head the same as casing width. You won't see both heads at once. Be safe, GBR
Door is already in place so altering casing and door are no longer an option. I have two ideas:
1st: Use my normal trim, rip top piece to fit and then use angles to match up miters.
2nd: Use 2" pine and rip to size. Simply run like a box.
1 - 8 of 8 Posts
