Hello!
This is a rather easy fix, actually. You can go to your local big box hardware store and purchase a Threshold sweep. Just make sure the one you purchase matches to the thickness of your door! You may have to cut the length to fit.
Most allow some sort of adjust, I.E. You slide it onto the bottom of the door, close the door and pull it down till it touches the threshold, install the screws. The screw slots are usually oval which allow you to slightly move the sweep up and down for optimum positioning. Good luck!
edit: A good tip also, sometimes the rubber seal will slide out of the aluminum frame easily, I usually crimp the ends of the aluminum frame (vice grips or channel locks will work for this) to pinch the rubber seal and hold it in place.
