hello,
I am new to the forum. I have an old home (built around 1900) that some previous owners have done some DIY with that was obviously not done correctly. For example the previous owners put in new outside doors, probably due to a suggestion by a Realtor.
I am not an expert but it is clear to me that these doors are not right. I'm not sure if this is something that is fixable or if I just need to replace these doors. The doors do not have any casing or molding installed, and the hinge framing is not even with the drywall inside. From the edge of the drywall the hinge framing goes in about an inch or so. Is this the case of a door that is just too small or is there a way to remedy this?
Thanks,
Brian
Thanks,
Brian
