1 - 20 of 33 Posts
I’m thinking about putting one of these: https://plexidors.com/product/plexidor-wall-series/ (size large)
Through a poured concrete wall in my garage. Pics below.
Thoughts on issues with this being an exterior load bearing wall?
The cost to do this, seems better than the cost of an actual door with a custom header etc to carry the load.
My thinking is that since the doggie door is opening cut would be 14 3/8 x 18 3/8 it’s far less an issue than a full sized door.
Thoughts?
· retired framer
renting a diamond chainsaw's terrific but, in the hands of a newbie, not the best idea impo,,, we own 1 & there's no way i'd let anyone else us it
14" demo saw & cut from both sides,,, cut wet to eliminate dust - overcut & patch to finish
What are the pit falls the videos make it look like a breeze.
· retired framer
i bet it does,,, chains & bars are extremely expensive in the hands of the inexperienced tho,,, come to think of it, no one in atlanta rents them
At the end, he does say something about a $300 chain. I would be you would have to buy the chain if you could rent the saw.
Discussion Starter · #16 ·
I would center it under a window and you don't have to worry about any extreme loads from above.
I assume under the window is a great spot as the header for the window should already be redirecting the weight to the sides of the window and down into the cement - leaving the cement under the window mostly load free, right?
· retired framer
Yes, I doubt it would hurt thru wall done anywhere, but under the window is one place you know you are safe.
· retired framer
Thanks - based on some of the convos about around a chain + saw rental perhaps it would be better to hire someone to cut the hole - hopefully it wouldn’t be TOO expensive. Wife says “I’m not qualified to cut through concrete in our new house” lol
Most of them have concrete coring in the company name around here.
· Remodel and New Build GC
Depending on your interest and sost factors, for a small dog door I'd probably use my bosch bulldog drill and a good 1/2 or 3/4 drill to "circle" the cut out and then a sledge to bust it out.
I think I would slightly over size the cutout and fill it in with a vinyl concrete to perfect square......rather than grind out the ridges that multiple drill holes will create.
You may likely run into some rebar that yould have to use a hack saw or recip to remove.
The bulldog is a great tool that you will find multiple uses for thru time....I use it a lot for digging with a spade bit and all sorts of demo work.
1 - 20 of 33 Posts
