I'm thinking about buying this house as a rental. The plumbing looks shoddy on this part of the house. I believe it used to be a breakfast nook that is now converted to a laundry room.
That looks more like dog scunge than mold to me. The oil from their dirty little bodies.I would be more concerned about the discoloration on the wall beneath the window.
Many inspectors require purple primer to prove you used it.Purple primer is usually a dead give-awy that it's a DIY job. A number of home & building inspectors have told me in the pst that when they see purple primer, they look harder and longer than they normally would, and usually do so for good reason. That said, it's hard ot tell if there is indeed purple primer or not.....
Not here, they simply require a pressure test to prove you used both..........Many inspectors require purple primer to prove you used it.
Passing a pressure test does not prove you used primer.Not here, they simply require a pressure test to prove you used both..........
