OK, I want to check on these ceiling light switches.
I have diagrams.
I bought this house 8 years ago, and I have not changed anything on this circuit. All the switches do actually work, I'm just not sure if they're done right. Also, I do not know what route the wiring goes around the house; I can only see what's connected in the electrical boxes. I is confoozed.
I have a kitchen ceiling light controlled by two 3-way switches.
On the same circuit, we have:
A second kitchen ceiling light controlled by one switch,
A laundry room ceiling lights controlled by one switch,
A porch ceiling light controlled by one switch,
A porch outlet (with weatherproof covering),
A bathroom ceiling light controlled by one switch,
A bathroom power outlet,
Two bedroom power outlets.
(The two bedroom outlets don't have power, but everything else does. They shorted out a while ago and I have not fixed that part of the circuit.)
1)
The 2-gang box in the laundry room (which happens to be closest to the circuit breakers) holds the switch for the laundry room light and one of the 3-way switches for the main kitchen light (light A).
There are 6 electrical cables in this box, as per the diagram.
2)
The 2-gang box in the kitchen holds the other 3-way switch for the main kitchen light (light A). There's nothing in the other side of this 2-gang box; they just installed a bigger box than they used.
There are 3 electrical cables in this box, as per the diagram.
3)
Another 1-gang box in the kitchen holds the switch for the second kitchen light (light B). It's on a wall that is between the other two switches, but that doesn't itself tell me how the cables are routed.
There are also 3 electrical cables in this box, as per the diagram. This supports my thinking that this switch and its light (B) are in the middle of this line, but it operates independently of light A, so it must be on a different branch. (right?)
My first question is, of course: WTF is up with those wires (in diagrams of box 1 and 2) that aren't connected to any fixtures or nuts? This seems inadvisable.
Second question: In the double-gang box... I guess cable 2 goes to the ceiling light A, and cable 3 goes to the laundry room light...? Even though they are coming into the box from below? Because those are the only cables that have a switch between them and everything else...
Um.?
Thanks for any comments.
I have diagrams.
1)
2)
3)
Um.?
