Do these porch columns provide any support, other than keeping the soffit from sagging?
The previous owners of my house put up fascia boards without priming / painting the ends. We all know how well that works out. Water got in between where the 2 ends meet, swelled the wood, let more water in, and rotted the fascia boards. The water also rotted a small section of my soffit. The soffits are plywood. I've been working to replace the rotted fascia's and came around to the front porch area. This one has the worst rot out of all of the ones I have replaced.
IMGP4174 by r0ckstarr, on Flickr
IMGP4175 by r0ckstarr, on Flickr
The rotten area is here in the circle. It's the 2 ends of the fascia's and a small section of the soffit underneath.
This section of the soffit is a 4x8 sheet of plywood. I outlined it in this picture here:
IMGP41782 by r0ckstarr, on Flickr
In order for me to remove this sheet of plywood, the column will have to come out. Can I just pop the column out, replace the rotten wood, and put the column back? Does the column offer any kind of support for the roof structure other than holding up the soffit board? Also, I do not see any visible screws or nails on the column, connecting them to the soffit. Are they just slid in place or will their be some form of screw / nail attaching them on the inside of the soffit that I would have access to once I removed that fascia board?
The column will also be replaced. I believe the previous owners didn't prime/paint the bottom of it and rain got to it as well.
IMGP4177 by r0ckstarr, on Flickr
I'm thinking that if I remove just the rotted column, and leave the other in place, I would be fine. But, before I take a chance of making an easy job harder, I wanted to ask to see what others thought.
