I am in the process of putting on a new roof and having my house painted. Should I have all of my soffit vents replaced while I am at it?
The current vents were put on when the house was built and were painted over. I have heard that it is not the best to have the vents painted as they can clog the vents up. Although if not painted, they will most likely be white and not blend into the house paint. Is matching of paint little concern vs. having the vents clogged?
Also, I have gotten a few of roofing bids. Most of the companies use subcontractors. One does not. Is this something that I should worry about? One of the companies that uses subs, I have heard good things about their work. Is that something that should concern me or not?I know the deal about the subs possibly attempting to do the work as fast as possible to get their paycheck....
Also, two of the roofers have provided a couple bits of information that I am not sure the difference in materials. Please help me clarify. One roofer says that he will install a Timbertex ridge and the other says that this ridge is not that good and will install a high profile type ridge. Is one better than the other or not matter?
Finally, my bath vents air flows into attic. Is this a problem? Since I am having my roof done, should I have them vented out the roof? Worth the time, money effort?
Thanks for input.
Thanks for input.
