I'm building a stacked block retaining wall. Wall will be about 14" high (3 4" courses plus 2" wall cap) above grade, with base course below grade, and about 60ft wide across the back of my yard. Wall isn't retaining a hill, just a raised level planter area with fence on top between us and the neighbor in the back. Wall is about 3 1/2 ft from the fence on my side. Similar situation on the neighbor's side. Also, we don't get a lot of rain here, something like 18"/yr. Do I need to bother with installing a drain pipe behind the wall, or is gravel backfill next to the wall and some landscape fabric to keep silt from coming through the wall adequate? If I need a drain pipe, what is recommended?
Thanks for your suggestions.
