I'm attempting to install a sliding glass door in an exterior brick wall but have some concerns with the construction process. I have heard that a door shouldn't be installed within 2-4 feet of a corner and was wondering if there is something that could be done to work around this and still maintain structural integrity.
As seen in the picture the wall is only partially sheeted and there is a diagonal strip running from the bottom right hand corner to the upper left hand corner.
It seems odd that the opposite corner has a door but I imagine the wall was assembled differently.
Can someone tell me if removing the studs and diagonal strip and replacing the area with a supported overhead 2 (2x6) would cause structural issues.
Thank you,
Eric
Thank you,
Eric
