I have DIY remodeling project that I need to finish and have many questions about getting the right equipment to finish the job. I'll try to be brief:
I have a built an entertainment center and trimmed out the fireplace, windows, and walls with panels (see photo below) and now I need to paint it all. I want to paint everything I trimmed out white.
My preference is Latex, but I want to spray it, as it would take a week to paint just one coat by hand.
I had bought a Wagner PaintCrew (still in the box an probably going back) as I have determined that I would be lucky to complete the job without this thing going belly-up. So I am going to take the $200 for that and apply it towards a Graco or Titan (leaning Graco) and am looking at the X5 (or XR5 or whatever proprietary model numbering Lowes or HD use).
I also want to use a smaller spray pattern as the 515 (or 517) that comes with this model seems to be too wide for this project.
Based on the assumption that I am resigned to seal off the room and cover EVERYTHING, here are my questions:
Is the Graco model outlined above good for this job? (also may plan to paint kitchen cabinets in the future with oil-based or laquer and want to make sure I can switch without killing the unit)
What size spray pattern would you recommend to best complete this job, based on my photos? (I have extensive 4" rails and styles, 4"-6" wide window trim, the large entertainment center and panels between 6" and 18")
I've been researching the Graco Fine Finish Tips. Will one of the higher flow rate models work with latex? (i.e. 214 ro 414) Otherwise, is there another suggestion on tips?
Finally, what is the best way to thin the latex paint (and primer) for the Sprayer and tip combination you would suggest? Otherwise, I am open to you trying to convice me to go another direction with Finish materials that I can do myself and under $500 for equipment and materials.
Thanks in advance.
Thanks in advance.
