This question/thought is, I think, geared more for the Home/DIY'er much moreso than a professional/contractor
... so please keep this in mind as you read on.
I wanted to (hopefully) spark an informative/insightful discussion here as to the idea of creating/building a DIY custom table saw set-up vs. simply purchasing a (standard) pre-made table saw.
PREFACE:
I love seeking out and reading "how-to" articles/blogs/videos on how to make all sorts of do-it-yourself projects. I've just started putting together my home "Weekend Workshop/Mancave" and one of the near-future tools I am going to want to be adding soon is a table saw.
THE CHOICE:
Insofar as pre-made/manufacturer table saws go, I have my eye on the RIGID 10" 15-AMP Heavy-Duty Portable Table Saw - $499 at HomeDepot.
I have also seen/found - and have been intrigued by - several tutorials/videos from those who have built their own table-saw setups using a circular saw. I am intrigued by the thought of creating a custom set-up - with various custom elements I would want. However, I also see some potential drawbacks to the DIY approach . . .
DIY PROs
- customize to/for what I want (e.g. materials, table size/length/width, track/fence, etc.)
- possible less cost than manufactured equivalent (depending on materials used)
- personal accomplishment/satisfaction of having created something useful from scratch
DIY CONs
- most circular saws = 7.5" blades, whereas most conventional table saws = 10" blade
- under-tabletop blade angle/bevel and height adjustment for circular saw
- quality/stability of table fence (depending on approach utilized)
- having to DIY everything vs. having it all ready-made for one to use
Those are, at least, the pros/cons I can think of off of top of my head. I'm certain there are plenty other items/issues I am forgetting or not thinking of ... and I am certain you all will provide additional thought/insight on this issue.
I am looking forward to an informative, constructive and educational discussion on this issue. Obviously, I haven't yet made up my mind as to which direction I will ultimately go - which is exactly why I am putting up the topic for discussion here.
PREFACE:
THE CHOICE:
DIY PROs
DIY CONs
