1 - 10 of 10 Posts
Hey All!
I'm in an 1840 structure, small, with two chimneys - one is functional, and needs a little work, the other is completely non-functional (it's sealed with cement, pics below) and dead-ends above a dirt crawl space.
I know nothing about this stuff - but to me it looks like it's beyond repointing, it's beyond my ability to repoint anyway. Should I have it repaired or just removed? Or maybe just taken down to where it's only a foot or two high and then resealed? Do I need a mason or just a handyman type person?
Any ideas on what something like this should cost?
Thank you all for your help and suggestions!
Rob
Thanks!
I was wondering that as I posting the pics - it's pretty shoddy. At first I thought it was just old but some of the cement looks kinda new.
Any reason why I should leave it and not just take it down?
Thanks again!
I love a firelplace but there's no place to put one. This was a chimney from 1888 for a woodturning stove and/or fireplace. After several remodels there's just no place to put it anymore :(
I have a question if the chimney terminates 1 foot above the crawl space ground What is supporting the weight of the chimney?
I also see pieces of mortar joint sticking out from the face of the brick I think this would indicate movement in that area. I would have a Structural Engineer look @ it.
I have a feeling the mason will tell you that your lowest cost option is to rip that thing down. I had that done on the unused chimney once. I was a little nervous about having a mason do roofing (patching the hole), but he seemed to have done a pretty good job of hole patch. I guess he gets a lot of practice.
Discussion Starter · #9 ·
There's a 12x12 petrified piece of oak holding up the structure and it runs right under the chimney. If I was going to use it I might have an engineer look at it but it's been sitting there for a LONG time and that 12x12 hasn't budged :)
1 - 10 of 10 Posts
