1 - 8 of 8 Posts
New House Newbie
I love the look of stripes in a lawn, just looks complete and well taken care of (other disagree I know). So I set out to buy a striper. Toro has a decent looking unit for around $80, but I figured I could do just as good. Here is what I cam up with.
-2' sch40 PVC
-aluminum flat stock
-1/2" all thread and nuts/washers to fit
-internal PVC caps
-$15-$20
`I measured outside to outside on my rear wheels to get a width for the PVC (22" in my case).
`All thread through the middle of the PVC caps and pipe. Fill pipe with concrete
`I should have just cut the 3' aluminum flat stock in half, but I bent and drilled holes for the first side then cut off excess which left me a few inches short of half left. Cut the flat stock in half first so that you have equal material to use for each side (or buy 2 pieces of flat stock; was $8 a piece here on sale). I chose aluminum because all I have to bend metal is a vise so it bent quite easy with my hands and a vise.
`Once the first piece of aluminum was bent correctly, I put that in the vise next to my next piece and bent the second piece to match the first. One note that I learned from looking at the Toro unit, angle the striper so that it pushes forward towards the back of mower deck). A Toro video said you will get better results
`I had to drill holes in my lawnmower tubing to bolt this up. You may already have a bolt going through a location close (lucky you!)
The only thing I am going to change is I am going to get a couple bushings to put on the all-thread so it rolls better and can still tighten the nuts on it. I have not been able to try this as yesterday it snowed a little here, so it may be a couple weeks until I get this going. Anyways, hope this sparks ideas for others and would welcome feedback on how to make this better.
J
New House Newbie
I'd fill that PVC with sand or concrete. It's the weight that presses the grass down.
Yep, its filled with concrete. I thought about sand, but my guess was that concrete is heavier.
"`All thread through the middle of the PVC caps and pipe. Fill pipe with concrete"
Master General ReEngineer
Ayuh,.... Is it gonna be mounted Rigid to the push handle, or Swingin' off the handle,..??
I see it complicatin' doin' 90°, 'n 180° turns,...
New House Newbie
My original thoughts was that it would just ride on top of the ground and move up and down with the terrain (you can see a small slot at the top of the aluminum on the last pic; i had just pins to put in those slots but switched it out to a bolt/nut), but when I was wheeling it around the garage, I ran over my floor drain and the roller actually lifted the back end of the mower up and then became a trailing striper instead of one that is pushed.
I guess I will not know how it maneuvers in turns until I try it out. Right now it just slides around on my garage floor.
Ayuh,.... On a corner, when ya push down on the handle to swing the front of the mower around, the mower is gonna pivot on yer roller, if rigid, ain't it,..??
1 - 8 of 8 Posts
