1 - 20 of 20 Posts
Bruce
We're replacing our cabinets, and getting a new dishwasher. Cabinets aren't here yet, but I'm starting to plan for appliance installation. The Bosch dishwasher we bought (http://www.bosch-home.com/us/SHX55RL5UC.html?a=b) has instructions for hard-wiring, although it says it can also be modified for plug-in connection.
The instructions just show the romex left bare (no conduit) running from the back of the wall under the dishwasher to the front connections. Is this really okay?!? Would it be better to purchase the power cord for it, and set it up that way?
My concern about this is knowing where to place the outlet so that it won't interfere with the dishwasher when I push it back into place.
Any thoughts?
Thanks!
You are fine just running a piece of romex out of the wall near the bottom. Leave a good 4' coiled up for now and cut it to length after the dishwasher is set and you are ready to tie it in.
A "Handy Husband"
Not true in many locations. Often you need to provide a disconnect. This can be a wall mounted switch or a plug and receptacle. Personally I like to put the receptacle in the adjacent sink base cabinet and install a cord/plug on the DW.
It's true as far as the NEC. If a certain location has a different amendment, then that is a different story. Kinda like the way you can't use romex in Chicago.
Although plenty of people do it with direction connection as stated in the manual, Bosch makes it very easy to hookup to a power cord.
So when I installed my Bosch (SHX45P06UC) dishwasher, I used an universal power cord kit to make my dishwasher a plugin unit which made it easier to remove for maintenance/troubleshooting/upgrades.
The 3 prong power cord has thicker sheathing and more flexible. In addition, 6' cord length gave me plenty of space maneuver the unit for maintenance/troubleshooting/upgrades.
One thing to keep in mind is that I haven't seen these cords with flat plug heads so I installed a recessed receptacle box. I could have installed a receptacle box under my sink but with water filters, multiple shutoffs, etc., I just did not want to chance it being exposed to water leaks.
You may want contact your inspector to see what method is acceptable for your town.
Good luck
DIY Enthusiast
If it's a dedicated line from the Panel wouldn't the breaker serve as the disconnect?
so what do they use in Chicago, BX? Do you know if there is a particular logic behind that decision (i.e. pests, etc.)
A "Handy Husband"
A disconnect has to be in sight of the appliance. Seldom is the panel close enough to the kitchen to meet that requiement.
Licensed Electrician
Only if you can see it from the dish washer.
Not true, a breaker lock is acceptable if out of sight. That is the point. You can't see the breaker, so you lock it to keep it turned off instead of visually monitoring it.
Reactions: rjniles
A "Handy Husband"
But a breaker lock takes care of this
I misread your post, I thought it said breaker box (instead of lock). Certainly a breaker lock accomplishes the requirement.
The more common theory is that this is a union code. If you are forced to use conduit, that rules out 95% of homeowners and unqualified handymen doing electrical work.
Licensed electrician
The 6' power code is a code violation. The NEC limits the cord length to between 3-4'.
Thanks for letting me know. I double checked the part (GE wx09x70910) and it says the length is approx 5'.
I know I specifically asked about this part with my e. inspector and he said it was acceptable (see installation manual) below)
I have him coming back next week to check and approve my other project so I will ask him again. Do you know which NEC section references this code?
Thanks
E2 Electrician
Not exactly true Jim... That measurement only includes the distance from the face of the attachment cord to the plane of the rear of the appliance.
So you can easily add another two feet to get to the front of the dishwasher.
Lic Electrical Inspector
Interesting. Never thought of it that way.
Thanks
Nice graphic!
1 - 20 of 20 Posts
