Greetings all, this is my first post
I decided to install a dishwasher, however the counter top is too low.
It seemed to me that I should be able to remove some of the layers of vinyl to gain some of the space needed for clearance.
I didn't look into the construction of my existing counter top, and in my naivete the project has ballooned into something much more involved that I initially anticipated.
Biggest concern:
Another Concern:
More Considerations:
Last thing:
I know I'm in over my head, but I don't have a ton of time and money to spend on this project, so any and all advice is greatly appreciated!
Thank you!!
Biggest concern:
The dishwasher felt is actually touching the underside of the counter top.
Making more space would be a big hassle...
Should I be concerned about heat?
I should be able to provide decent ventilation in the back and on the sides. Hopefully that would be sufficient.
Another Concern:
As you can see, I had to cut away the flooring in order to slide the dishwasher into place. Underneath was (ugly) asbestos tiling.
I'm not ready to completely rip out and tile my floor especially given the asbestos, so I need ideas on how to effectively cover this cut out while still being able to pull out and access dishwasher.
I read on a different forum that some people will put in a removable tile section... any other ideas?
Something functional/temporary?
I also read that it's standard practice for dishwashers to be installed on top of tile. Another said that contractor laid vinyl in and around dishwasher to waterproof the bottom and sides
Would it be okay to wrap the this cabinet with vinyl?
I'm also wondering about the cut out in the front - there isn't really anywhere for water to go...
Last thing:
Do I need to rebuild the broken concrete section?
My current plan is to get a thin piece of moulding, same thickness as the tile above, and create transition between the countertop and face of the cabinetry.
This way I could avoid the hassle of build something to hold concrete/mortar into place in the space above the dishwasher (and anywhere else where concrete breaks from removing tile.).
It would be ugly underneath the surface, and it's certainly a hack job, but...
Would there be any other problems with this?
Thank you!!
