There's a backstory to this which I can get into later, but I'm going to hit up the key points...
Long story short, I put HardiBacker in my kitchen a year ago.
I've been walking on it for the past year... Just raw HardiBacker.
It's a Kitchen... It's had stuff spilled on it. My dogs come in and out of the sliding glass door and track mud on it...
Is there a way to clean it? I've scrubbed and scrubbed with a stiff bristle brush and it won't come as clean as new.
Do I have to worry about this? Will Thinset bond to the dirty HardiBacker?
Also, when I was originally putting it down, I used the HardiBacker screws to attach it to my old wood subfloor. (Same section as HardiBacker at Home Depot... "Backer-On" is the brand name.)
When I put the first few in, they did not completely counter sink into the HardiBacker... They ended up flush at best. Most have the conical section of the head sunk into the HardiBacker, but the surface of the head is still slightly over the surface of the HardiBacker.
If I leaned my weight on the drill and pulled the trigger, the tip of the Square or Phillips drive bit would break off... So I left them at that. I did put them in while the Thinset under them (between the subfloor and the HardiBacker) was still wet.
