I would like to know what the difference is between different types of RG6 coaxial cables.
I know the standard ones we use indoors.
Then there are some that are rated "WEATHERPROOF".
Then there are some that are rated for "DIRECT BURIAL". I think the direct burial cable is weatherproof but the weatherproof cable is not necessarily for direct burial.
I have a picture from a vendor showing both but it is not obvious to me what the difference is.
My specific questions:
(1) Is the difference in the actual connectors? or the actual cable? Both connectors look the same to me.
(2) If there are weatherproof vs direct burial cables, are there weatherproof vs direct burial connectors?
(3) I tried a regular RG6 coaxial stripper to strip a direct burial RG6 cable provided by my cable provider, a piece of left over, and I cannot get a standard RG6 connector on it. The foam insulated portion will not go inside the hole fully, making me think may be the direct burial cable needs a direct burial connector? Or the stripping needs to be different?
· Super Moderator
Yes, I agree, they are special connectors with a HD weatherproof plastic seals at the end, as in your photo, to prevent water from getting in.
in reference to the cable; No doubt the direct burial is more hd gauge and would require a special connector to fit that cable. Just my opinion.
Usually the direct burial cables have some sort of siliconized gel where the braiding is, to keep moisture out from the core and foam center. The connector should fit, although your piece may be a quad shield cable, which would need a larger connector, you can tell this by multiple layers of foil wrapped around the braiding(s). There may also be a marking, such as RG-6Q on the cable.
The difference between the indoor/outdoor is usually UV resistance, and maybe a more cohesive outer jacketing to keep moisture out.
· Master Electrician
In general (but not always) is the difference of the outer shielding / casing. The inside (the part that carries your signal) is generally the same.
As has been suggested, there likely will be different connectors for indoor, damp / wet and underground. It is not recommended to use connector underground (unless you have a repair to make); even when I make a UG repair, I will generally add a couple layers of heat shrink to protect the connector and prevent the ingress of moisture.
Cheers
John
