Posting duplicate posts two min apart wil not solicit an answer any faster. All of the members here are "volunteers" in a sense. If someone is familiar with this system I am sure they will answer when they read this. Please be patient.
I know...why didn't you get the infinity controls?The zone control is not Infinity. It is a Carrierr Comfort Zone II controller. The out door unit is a Carrier performance HP model # 25HCB6.
Beenthere did that.It's a new home. I upgraded my system from the standard builders grade. Since I'm in NE Pa. the system is mainly designed for heating. The HVAC contractor suggested this set-up. I questioned about the Infinity controller and he stated that the CZII was sufficient enough for my needs. Seems to work well. No complaints.
Can you answer my question about whether the dip switch setting on the furnace should be set to off and the stat set to comfort, or should both the furnace and stat be set up for comfort?
Thanks.
Only the furnace should need set.
