So, my whole home humidifier that I installed about 3 years ago hasn't worked in about 6 months so I thought the apocalypse would be a good time to work on it.
I'm a bit stumped, so I was hoping someone would be able to point me in the right direction.
First, I checked the water supply. It's on and works. I took off the brass water valved and soaked it in some CLR to try and remove mineral deposits if any were there.
Still nothing.
I got out my E-meter to check contunity / voltage to the various components, and here's what I got.
Power at transformer: good, 120V.
Power at pressure switch: same.
Power out of pressure switch: None.
Power at solenoid: None.
Since no power was coming out of the pressure switch (while unit was running), my first thought was to replace it, which I did and it didn't do anything.
My next thought is to replace the solenoid, but since I'm not getting any power out of the pressure switch, I'm not sure how/if that could help. If the pressure switch isn't being triggered, it's not sending a signal for power to the solenoid, so a new one wouldn't make any difference.
It's a bit annoying, I put it all in and worked fine right out of the box, and I don't want to have to get a whole new unit, but also don't want to keep buying replacement parts which may or may not do anything.
Anyone have any advice? I have also attached a picture of the disassembled components with notes.
Other notes:
I noticed the voltage out of the transformer was 120V, but the label on top of the pressure switch (where the wires from the transformer input) say '24VAC' in. That seems like a problem, but do transformers go bad?
Also, I hooked the power leads from the transformer directly to the solenoid to bypass the entire controls system, and it vibrates and makes a humming noise, but does not allow water to flow. This makes me think that the solenoid might need to be replaced too, but it won't matter if there's no voltage coming out of the pressure switch, right?
Still nothing.
Other notes:
