I have A Westinghouse Pro 12000 generator. 12,000 running ways, 15,000 peak. It's a beast. Had it just over a year, which is why I'm not getting warranty repairs done.
The generator has slowly gotten worse. Initially it would start and then shutoff after 10 seconds or so. It seemed that we could resolve it by leveling the unit better. Well now it seems clear that although leveling helps the biggest problem is that it stays fine in peak power but kills as soon as it goes into idle. We've discovered that if we plug something in before turning on the generator then it forces the unit to stay in peak power and therefore won't shutoff. If we run it like that for a few minutes then we can turn it off and restart it without problems when it goes into idle. It's almost like it only struggles when the engine is cold. Seems to me that should be the big clue to what's wrong. Anyone have some thoughts?
I live in a smaller city so no one is officially able to work on Westinghouse generators. The repair guys thought my problem was the carburetor flooding. They cleaned it out and the same problem existed. They thought maybe the valves were too tight. They loosened them and the same problem exists (after the mechanic left and the engine had cooled again).
Thank you in advance for your help!
