I'm remodeling my kitchen and am splitting off receptacles and adding new 20A circuits. I'm also breaking off the feed for the bathroom from the kitchen light circuit.
I have all the new feeds pulled into the boxes and everything hooked up. I'm trying to decide what to do with the old feeds and interconnections I took out. Some of the cable I have exposed in a hole in the drywall and some are cut off in the receptacle or switch boxes. I would have to tear apart all my walls to get these wires out since they are stapled to the studs, go around corners, etc.
I plan to just wirenut the hot, neutral, and ground together on the cable ends in the wall so if someone finds them in the future they are clearly shown to be not used circuits and if someone happened to find the other end and try to hook anything up it would trip out and you wouldn't be left with a hot wire cut off in the wall.. The couple cable ends in the boxes I can't really get shoved out of the box so I'm debating wether to wire nut the ends together and shove them in the back of the box or just cut them about as flush with their entry into the box as I can get.
Does this sound reasonable or are there other methods I'm not thingking of? Are there code issues with this?
