1 - 6 of 6 Posts
What should be the typical temperature difference between the intake and "exhaust" of a split system AC? How much does it depend on the intake temperature? I'm guessing that if the inlet is 40F vs 80F, delta T will be lower.
I'm talking about cooling.
I recently bought my first home and the HVAC system is very very old. With a 65F return the delta T is only 9 degrees. I'm trying to decide weather to get it serviced and make it last however long it will last, or bite the bullet and get a sweet 16 SEER system and that fat government rebate.
· In Loving Memory
9° is not much.
So it has a problem of some sort.
Weather its a diry coil, or low on charge or some other problem, can't say.
Depending on your location. You may be better off getting a new system. And upgrading to a heat pump.
The price difference is covered by the rebate. Plus you save some money on your heating bill every year then also.
1 - 6 of 6 Posts
