:biggrin2::biggrin2: Thank you for the info!!!If you are on a windows pc; Hold down the alt key, then on the number pad, type 0176 then let go of the alt key and you will get the degree symbol. Examples; °°°, 99°,110°
If you are on any other media, I'm not sure. You could always google the degree symbol and do a copy and paste that works as well.
I don't know why they don't have it on all windows compatible keyboards. I use it all the time and it's always a hassle to get it.
Hope it works for you to Doug.
35° too cold for me!! I looked up the character map - thank you!! Can I get windows 10 for free?? I have looked @ you tube & tried but no luck. Have window vista now @ have not used this computer very muchToday's high was a balmy 35°. :surprise:
One less number to type and remember. Thanks joed.ALT-167 also does it 79º.
THANKS!!!!! 95º :vs_karate: & up is what I like. I do A/C work - most elect heat in this area & they don't break down as much as A/C :vs_mad:One less number to type and remember. Thanks joed.
45º.. l Like it. :thumbsup::thumbsup:
Give us some attic temps° this summer.:surprise:THANKS!!!!! 95º :vs_karate: & up is what I like. I do A/C work - most elect heat in this area & they don't break down as much as A/C :vs_mad:
2013 attic--house metal roof 213º hottest one for me. Usually around 140º to 154º & most AH are in attic....Give us some attic temps° this summer.:surprise:
With approx. 150 attic degrees it seems to me about 10 gallons of some CPVC water pre-heat would be a good plan for those attics.2013 attic--house metal roof 213º hottest one for me. Usually around 140º to 154º & most AH are in attic....
That's a great idea!!! With 3/4 CPVC how many feet- the more the better??? or even 20--30 feet would help somewhat??With approx. 150 attic degrees it seems to me about 10 gallons of some CPVC water pre-heat would be a good plan for those attics.
To approach 10 gallons, about 60 ft. of 2 inch sch80 cpvc would be needed and hope the attic doesn't exceed the max. rated temperature of 200°F.That's a great idea!!! With 3/4 CPVC how many feet- the more the better??? or even 20--30 feet would help somewhat??
A little weight also-If I remember right (USAF fire dept)many yrs ago 8.35 lbs per gal of water- think OK with temp's One long run with elboe's? or use "T"sTo approach 10 gallons, about 60 ft. of 2 inch sch80 cpvc would be needed and hope the attic doesn't exceed the max. rated temperature of 200°F.
