What are you building? Since you want an accurate definition the specific use and conditions permit similare slabs that are not exactly "floating", but are generally called floating.
A true "floating slab" example would be a garage slab the is poured between stem walls. It is not attached to the stem walls and is supported by the compacted soil beneath it.
The advantages are less of a tendancy to crack since the edges are not tied and the thickness and reinforcement can be less that a typical structural slab.
A basement floor is very similar, but not exactly the same. Much thicker slabs like slab foundations and post-teneioned slabs are also similar, since the soil supports the slab.
Discussion Starter #3
Lets use the true definition, would a product that is 3/8" thick continuous vapor barrier acting as a cushion like thin foam products now being used under wood floors have a benefit? The product is called Slab shield.
You would have to check with the flooring manufacturer to see that the requirements are the materials to use under a wood floor. This will affect any flooring material guarantees.
The term "vapor barrier", which is more correctly referred to as a "vapor retarder" depends on the material AND the thickness.
Discussion Starter #5
I apologize I didn't phrase my question clearly. The question is using the flexible foam product under concrete. I know that improves cure time, radon and termite barriers.
