My well pump pressure drops from full 50 lb. pressure to the 30 lb. cut on pressure about every 3 minutes. I have checked the bladder tank, and all water lines in and under the house and found no leaks. As fast as the pressure bleeds down I suspect the well check valve. If that is the case can I install an upper check valve so I do not have to have the well pulled.
