We moved into our house last year and one thing we had been wanting to do was replace the decking. The current decking was 2x4s and had not been properly treated, so was in pretty rough shape.
We purchased new decking and went about removing all of the old decking. When I got that removed I ran into a few other problems. What I'm looking for is some advice as to whether this can be repaired or if I should just consider scrapping the whole thing.
Some pictures should help me illustrate.
This deck seems to be built as a free-standing deck. It does not have beams, just posts with joists bolted to them around the outside frame. The dimensions are 12x24 and there are three 6" posts on each side. There is also one post in the middle.
First question, should this deck have beams?! it doesn't seem right...
Now, while the deck is free-standing it's also bolted to the house... straight through the siding.
There also is no flashing where the deck attaches to the house. So the siding, in at least one area, seems to be rotting... great.
Speaking of rot, I found at least 8 joists that had some level of rot. Looking at replacing these I noticed all the joist hangers were improperly installed. Each was installed with screws, usually just 4.
Can I even correct this without removing, and moving all of the joist hangers to new locations?
Here's another fun bit. This is in the joist/ledger attached to the house. There is a vent (for what, I'm not sure) which is cut straight through the board. It looks like it's split in the bottom also.
And finally, speaking of posts. There are three posts which support the pagoda. This is one:
This is another:
I'm not sure why these posts are split, or if the first one is properly rebuilt, but again it just doesn't seem right.
So my questions:
1) Do I need to remove the ledger board/joist that is attached to the house because of the siding rot? I think this could be the biggest problem, and could lead to the whole deck coming down. I don't see how to remove this board without it.
2) if the deck survives, do I replace all the joists and joist hangers?
3) I guest the biggest question, is should this deck survive?
Thanks for your help everybody, hope you enjoy the failings of others I've discovered :whistling2:
This is another:
So my questions:
