Apologies in advance this post got a little long!
Hello, just discovering these forums while researching a project and they seem like a great resource. The project I'm researching is a deck build/rebuild on a house we bought last year. The current deck is 30+ years old and is starting to get pretty rough, I'm concerned about building it back exactly the way it is now though because the spacing of the joists seems pretty far apart and based on the charts I've looked at the beam may not be quite thick enough. The deck is essentially on the 2nd story of the house and extends out over the walkout basement. The entire frame, joists, posts, and beams, are made of rough cut 4x6 cedar. The joists are 4' on center and the beam span is about 6' except on the part over the walkout where there are two sections which are 16'. Here's a drawing of what I currently have, the blue lines are the current joists 4' on center, its also worth mentioning the way these posts attach to the house is they actually run through the rim joist on the house and rest on top of the concrete basement walls.
