Hey guys,
In the beginning stages of planning a deck/paver project for the spring. Right now, I’m trying to get my deck plans straightened out.
*The dimensions will be roughly 16x12 built from #2 PT pine. 16’ (length) will be secured to house
*The deck will be attached to the house via ledger board.
*Footings will be concrete piers approx 36-48” deep. I’d like to keep these 5’ or 6’ o/c as our local code requires any footing within 5’ of foundation to be 8’ deep (and I don’t want to dig 8’ down in clay)
The questions I have are around lumber dimensions. I plan on going 12” o/c with the joists.
1. Can I use 2x8 lumber for all this? Or do I need to step up to 2x10?
2. I read on decks.com that if I have post spacing 6’ and a joist span of 12’ then I can use 2 2x8. What does this mean? Do I sister (2) 2x8s? or one on either side of the post on top of the footings?
3. I’m assuming joists should run perpendicular to the house & ledger board. Or should they run parallel?
4. Do I need footings underneath the deck or only the perimeter?
Thanks guys, hopefully with these few questions answered I can put pen to paper and finalize the plans to submit for permit.
