See below for a layout of my deck piers. I have read through the Prescriptive Residential wood Deck Construction Guide and have tried to base my designs off its codes. I am not required to follow codes in my area, however.
Note: Frost line is 12" in my area.
I have couple of questions that I hope you guys can help me out with.
1. If I read through correctly, my pier footings are to be 24" x 24" x 11" and the piers would be 8" diameter. This seems like overkill to me. Does this seem right to you?
2. Overall deck height will be 2' so I will plan on not using 6" x 6" posts between pier and beam. Instead, I will rest the wooden beams directly on the concrete pier. Any concerns there?
3. What fastener would you recommend to connect the 2x10 beams to the concrete pier? I would like something adjustable in case I'm slightly off in my X direction or height.
4. I will have close to $900 in just material for the footings and piers. This is not counting digging equipment rental. Are there alternatives such as the Titan Deck Foot anchor that would work just as well?
Thanks and I appreciate any comments you can throw my way.
